How to restore /jffs/zoneinfo?
XIII
Part of the Furniture
Today I discovered that the shell is reporting UTC time instead of my local timezone (CEST):
date
Wed Jun 18 13:09:40 UTC 2025
I tried to fix that by setting the TZ variable:
export TZ=Europe/Berlin
date
Wed Jun 18 13:09:40 Europe 2025
So while the text changes from "TZ" to "Europe" the hours remain the same (13) instead of the +2 for CEST (15).
Then I noticed that /etc/localtime is a link to a file in /jffs/zoneinfo, but the entire "zoneinfo" folder does not exist in JFFS on my GT-AX6000 (running ASUSWRT-Merlin 3006.102.4_0).
  1. How can I fix this?
  2. Can I use "CEST" instead of "Europe/Berlin"? (which I used as an example)
Manually linking /etc/localtime to /opt/share/zoneinfo/Europe/Berlin seems to fix this, but will this survive a reboot?
(Or do I need to do this in a script that is executed every boot?)
I've never heard of a /jffs/zoneinfo directory existing before. So unless this is something new in the 3006.102 firmware I'm guessing that some third party script created it.
Normally /etc/localtime points to something under /rom/usr/share/zoneinfo as defined in the webUI. e.g.
# ls -l /etc/localtime
lrwxrwxrwx    1 admin    root            37 Jun  4 11:22 /etc/localtime -> /rom/usr/share/zoneinfo/Europe/Dublin
See also this recent discussion regarding the difference between /etc/localtime and $TZ:
I suggest you disable JFFS custom scripts and configs in the webUI, reboot and see what /etc/localtime now points to.
I think this extra zoneinfo comes from the NextDNS installation.
I do indeed run the NextDNS CLI Client... Good catch!
(Surprised I haven't noticed this before)
Confirmed: after restarting the NextDNS client, /etc/localtime again points to /jffs/timezone...
Yes, I suffer from way more `asd` deletions than I'd like (all false positives).
Why are all the custom scripts generated by this community not affected by `asd`?
I believe Asus setup exclusions for the scripts and addons directories unique to Merlin.
Probably because they don't put stuff in /jffs unless it's under /jffs/scripts, /jffs/configs or /jffs/addons. Anywhere else and it's likely to be deleted.
