How to setup a squid cache for websites, windows updates, etc?
bamboo
I read this guidefor setting up a squid cache to speed up browsing, and I'd like to do it in rmerlin. How much of the guide is transferrable? I've already installed squid via entware, and pasted the conf in the guide, but past that, it's all greek to me. Can anyone help out? Thanks!
Allow me to clarify what problems I'm having. I install squid as per the guide, and edit the conf file appropriately. However, the sticking point seems to be when I attempt to add this "nobody" user. I get no confirmation that any action has taken place.
grep -q ^nobody /etc/group  || echo "nobody:x:99:" >> /etc/group
grep -q ^nobody /etc/passwd || echo "nobody:*:99:99:nobody:/var:/bin/false" >> /etc/passwd
results in nothing. Here is a copy of the text
ASUSWRT-Merlin RT-N66U_3.0.0.4 Fri May 9 21:15:50 UTC 2014
admin@RT-N66U:/tmp/home/root# grep -q ^nobody /etc/group || echo "nobody:x:99:" >> /etc/group
admin@RT-N66U:/tmp/home/root# grep -q ^nobody /etc/passwd || echo "nobody:*:99:99:nobody:/var:/bin/false" >> /etc/passwd
Just for laughs, I pasted "grep -q ^nobody /etc/group || echo "nobody:x:99:" >> /etc/group
grep -q ^nobody /etc/passwd || echo "nobody:*:99:99:nobody:/var:/bin/false" >> /etc/passwd" into the ssh terminal all together, resulted in the same lack of response (No surprises here).
So lets say that it is creating this "nobody" user and simply isn't giving me any confirmation, here is what happens when I attempt to move onto the next line in the guide, "squid -z"
admin@RT-N66U:/tmp/home/root# squid -z
2014/05/27 22:09:41| WARNING: '127.0.0.1' is a subnetwork of '127.0.0.1'
2014/05/27 22:09:41| WARNING: because of this '127.0.0.1' is ignored to keep splay tree searching predictable
2014/05/27 22:09:41| WARNING: You should probably remove '127.0.0.1' from the ACL named 'localhost'
2014/05/27 22:09:41| WARNING: '0.0.0.0/0.0.0.0' is a subnetwork of '0.0.0.0/0.0.0.0'
2014/05/27 22:09:41| WARNING: because of this '0.0.0.0/0.0.0.0' is ignored to keep splay tree searching predictable
2014/05/27 22:09:41| WARNING: You should probably remove '0.0.0.0/0.0.0.0' from the ACL named 'all'
2014/05/27 22:09:41| Creating Swap Directories
FATAL: Failed to make swap directory /opt/var/squid/cache: (2) No such file or directory
Squid Cache (Version 2.7.STABLE9): Terminated abnormally.
CPU Usage: 0.000 seconds = 0.000 user + 0.000 sys
Maximum Resident Size: 0 KB
Page faults with physical i/o: 0
This is a little advanced to me, but it seems that I need to edit the conf file?
Then, lets say I was supposed to also ignore this warning and input the next part of the guide, "/opt/etc/init.d/S80squid start" into the terminal, it results in this
admin@RT-N66U:/tmp/home/root# /opt/etc/init.d/S80squid start
-sh: /opt/etc/init.d/S80squid: not found
Now, I never expected the guide to be exactly copy and paste, but I'm at a loss for what I should augment to allow this to work on asuswrt-merlin. Any suggestions?
Those two commands are simply appending a line to /etc/group and /etc/passwd files if they do not already exist there. Check the files to see if the change was made
cat /etc/group
cat /etc/passwd
... There's your problem.
mkdir -p /opt/var/squid/cache
chown -R nobody:nobody /opt/var/squid/cache
chmod 777 /opt/var/squid/cache
