How would you troubleshoot and solve this problem?
domic
ASUSWRT-Merlin RT-AX86U 386.7_2 Sun Jul 24 21:37:08 UTC 2022
-sh: /jffs/configs/profile.add: /tmp/mnt/entware-usb/entware/bin/fish: not found
admin@RT-AX86U:/tmp/home/root#
I have done the following troubleshooting so far:
1. Rebooted router
2. Unplugged entware USB drive, refreshed disks in WebUI and plugged in USB drive again, then restarted Entware applications in scMerlin.
3. Looked inside every script file in /jffs/scripts for clues, also looked inside /jffs/configs/profile.add.
4. Wiped syslogs with script, rebooted router and downloaded syslog that contains every single logged event for that boot.
Anything else?
It does, the drive is mounted, ls/nano etc can find it. It used to work fine.
Post the output of the following two commands:
cat /jffs/configs/profile.add
ls -l /tmp/mnt/entware-usb/entware/bin/fish
1. Rebooted router
Anything else?
Have you tried a different usb drive? Maybe it is dead.
#!/bin/sh
export RCLONE_CONFIG="/tmp/mnt/entware-usb/entware/etc/rclone.conf"
admin@RT-AX86U-6998:/tmp/home/root# ls -l /tmp/mnt/entware-usb/entware/bin/fish
-rwxr-xr-x    1 admin    root       1647704 Jul 21 12:43 /tmp/mnt/entware-usb/entware/bin/fish
Wait... Is there any problems running Asus Download Master together with Entware?
Why would they collide?
To my knowledge, if it were dead it wouldn't mount in the first place.
Actually many USB drives fail to "read only". Run into it a lot. Can mount it, read the files, copy them to another drive, but try to write or change attributes, format, etc, and the operation fails.
Worth a try, considering it was working fine and now isn't, it's a sensible test.
