https://www.costco.com loads, but not costco.com
Yet again today my ISP seems to be blocking my NTP and dnscrypt queries; its been fine for months but on occasion it goes down no matter what service or tricks I try; ICMP to IP works. VPN works great, so I want to set up a fallback to send all dnscrypt queries through the OpenVPN client tunnel; if these issues were not happening to me I would feel a lot more comfortable using DNS with my provider, though it may not only be ISP but any middle box on the line can interfere; not to mention hackers on the local ISP gateway. When you are trying to stop your government from killing babies and providing citizenship for al qaeda, sometimes the ****ers get uppidy. My ISP router was being hacked as well, if I dont use protections like DNScrypt & a quality router, I am fair game for hackers.
I think a lot of these issues I have been experiencing with https and other sites not working of late had to do with changing the MTU to 1492 on my AsusWRT; I changed it back to the standard 1500 and everything seems to be working fine again. The router was going hard hammering the subnet with icmp presumably for troubleshooting reasons after I changed it.
Hmm, I just upgraded pixelserv-tls, maybe this had something to do with it: (i clear cache and don't store certs in the browser)
  • Upgraded OpenSSL to 1.1.1b for pixelserv-tls static binaries. OpenSSL 1.1.1b provides better compatibility for client browsers and apps.
  • Added logging on LEVEL 2 when a client disconnects before a response is sent i.e. a 'cly' event
One example being I have to use my ISP DNS to receive un-metered “data-free” streaming for Spotify and Netflix. So that’s a nuisance.
You can use make dnsmasq use your ISP's DNS for only those domains and still use whatever you choose for everything else. Just put:
server=/*.netflix.com/*.nflximg.com/*.nflxvideo.com/1.2.3.4
in your /jffs/dnsmasq.conf.add file where 1.2.3.4 is your ISP's DNS. Make another line for Spotify and you're golden.
Wow thank you sbsnb, never heard of round-robin dns before. Yes I just found that opennic.org is on a different ip than www.opennic.org, and one of the ips is on a blocklist, im not sure how that got there; does Skynet have an intrusion detection system that auto-bans things like this? or is it a blacklist / whitelist only model?
EDIT i notice skynet has banned multiple opennic.org ips, i whitelisted one and yet it still was blocked at another IP; what are the odds? why is this happening?
EDIT:
167.99.4.63 & 104.198.14.52
Edit: make that 3 so far:
142.93.122.177
Why do you trust that the regulations are properly enforced against all DNS providers? I'm genuinely curious.
This must be a Swiss thing. My country is not perfect, but some things are very good here.
That includes the laws and its enforcement and independent control mechanisms that work really well.
dnamasq doesn't support wildcards like that. Just using the below would do.
server=/netflix.com/nflximg.com/nflxvideo.com/1.2.3.4
$ echo "server=/example.com/1.1.1.1" >> /jffs/configs/dnsmasq.conf.add
$ echo "server=/*.example.com/8.8.8.8" >> /jffs/configs/dnsmasq.conf.add
$ echo "server=/test.example.com/8.8.4.4" >> /jffs/configs/dnsmasq.conf.add
$ service restart_dnsmasq
Done.
$ nslookup example.com & nslookup foo.example.com & nslookup test.example.com
Server:         127.0.0.1
Address:        127.0.0.1#53
Non-authoritative answer:
Address: 93.184.216.34
Address: 2606:2800:220:1:248:1893:25c8:1946
Server:         127.0.0.1
** server can't find foo.example.com: NXDOMAIN
Server:         127.0.0.1
** server can't find test.example.com: NXDOMAIN
And from the dnsmasq log
using nameserver 8.8.4.4#53 for domain test.example.com
using nameserver 8.8.8.8#53 for domain *.example.com
using nameserver 1.1.1.1#53 for domain example.com
query[A] example.com from 127.0.0.1
forwarded example.com to 1.1.1.1
reply example.com is 93.184.216.34
query[AAAA] example.com from 127.0.0.1
reply example.com is 2606:2800:220:1:248:1893:25c8:1946
query[A] foo.example.com from 127.0.0.1
forwarded foo.example.com to 1.1.1.1
query[A] test.example.com from 127.0.0.1
forwarded test.example.com to 8.8.4.4
