Huawei B818 Cat 19 + Asus RT68u - Wifi extender
psi12
My parents have problems with singal on 1st floor if router is based on the 0 one.
They have Huawei B818 Cat19 router with sim card for LTE + they also got ASUS RT68U. Connecting both doesnt really help much as speeds are similar on B818 or when its connected via lan to RT68U and its the main one.
Can you suggest any wifi extender? Should i buy one from TP Link/Huawei maybe and put it somewhere in the middle floor to have better speeds on 1st floor if router is as mentioned above based on 0 one?
Or maybe i can get some wifi extender from Asus and use Aimesh or sth so that B818 with sim would be connected to 68U, this would be the main router and then the asus extender would catch the signal from it and send it further.
I appreciate all the help
Thanks,
