porfavorhelp
Can any body post me a picture of Asus Stock Firmware WAN DNS configuration. In one of the firmware they change something here. So that is why I want to see please. Thank you!
Over the past time there have been changes in the WAN page.Can any body post me a picture of Asus Stock Firmware WAN DNS configuration. In one of the firmware they change something here. So that is why I want to see please. Thank you!
Which router and which firmware? The only recent change is the addition of DoT. Is that what you want?Over the past time there have been changes in the WAN page.
It helps to indicate the router you have, the firmware your router has and your WAN Connection Type.
The page given above is the very default page, for many that is fine. When you need to set another WAN Connection Type, the page does change with other fields.
GT-AX11000 firmware Version 3.0.0.4.386.44266 they said "Modified the DNS setting and router's DNS can be assigned to the LAN side DNS." What is that?Which router and which firmware? The only recent change is the addition of DoT. Is that what you want?
It means the WAN DNS server setting can be set to an IP address on your LAN rather than having to be an external address on the internet. This was apparently not possible before (or didn't work properly). This is useful if you have your own DNS server elsewhere on your LAN.GT-AX11000 firmware Version 3.0.0.4.386.44266 they said "Modified the DNS setting and router's DNS can be assigned to the LAN side DNS." What is that?
This is more a bug fix than a new feature. The previous firmware was setting a static route to the WAN DNS, which would fail to work if you were using a DNS within your LAN (for instance a Pihole, or a Windows DC). This should be resolved in this release.Modified the DNS setting and router's DNS can be assigned to the LAN side DNS.
Are those pictures from Merlin or Asus Stock Firmware?Allright, you read that in the firmware release notes:
2021/07/08 66.29 MBytes
ASUS GT-AX11000 Firmware version 3.0.0.4.386.44266
1. Improved connection stability.
2. Modified the DNS setting and router's DNS can be assigned to the LAN side DNS.
3. Fixed DoS vulnerability from spoofed sae authentication frame. Thanks to Efstratios Chatzoglou, University of the Aegean, Georgios Kambourakis, European Commission at the European Joint Research Centre, and Constantinos Kolias, University of Idaho.
4. Fixed envrams exposed issue. Thanks to Quentin Kaiser from IoT Inspector Research Lab contribution.
I think they mean the additional DoT (DNS-over-TLS) setting in the WAN page and (if that is new?) the DNS entry in the LAN > DHCP page.
The following examples are from my RT-AC68U 3.0.0.4.386.45934.
WAN page:
LAN > DHCP page:
NB: mind that 3.0.0.4.386.44266 is not the latest firmware, there are newer versions with a whole lot of security fixes.
AsusAre those pictures from Merlin or Asus Stock Firmware?
Welcome To SNBForums
