Hello,
I currently have an Asus RT-AC68U serving my 2500 sq ft house. Signal at remote parts of the house is ok in general and I don't have any glaring connection issues. I have a 2nd one that I've setup as AiMesh, but when it's on, I have too many connection issues (drops, stalls, etc). Either way, I wondering if I should just ditch the older wifi technology and get a Wifi 6 router with multiple satellites.
The thing is I really like the Asus router running Merlin for my network management and I also have an external hard drive connected that I use frequently.
Would it make sense / is it possible to get a Wifi 6 network solution and just put it in bridge mode to use as house wifi access only? I presume I would put the main Wifi 6 router (configured to bridge mode) near my Asus and connect the Wifi 6 system router via it's internet port to an ethernet port on the RT-AC68U. And then reconnect all of my clients to the Wifi 6 network solution. Then I still manage my internet access via the Asus (VPN, external hard drive, QoS, traffic analyzing, etc). Is that all correct?
What kind of improvement will I even see, if any, moving to Wifi 6? I don't seem to have a problem streaming a 4K video from my router to a fire TV stick on the other side of the house via Kodi.
If this did make sense and I were to proceed, is the Asus router slowing anything down at that point or it's still quite capable to provide all of the internet routing for many devices?
Thanks in advance.
Thanks in advance.
