inconsistent settings.
homeauto
I just updated RT-AC68U to 384.7. and had some issues with custon vlan settings, which was used to work. After digging it more, I noticed that "robocfg show" gave different result than before. basically, in newer firmware, CPU ports moved from 5 to 8, , it cause inconsistent settings between robocfg and "lan1ports" and "lan2ports" in nvram. is it expected? is there any setting I could change CPU port back to 5 for robocfg? Thanks!
robocfg result from new firmware:
VLANs: BCM5301x enabled mac_check mac_hash
1: vlan1: 1 2 3 4 8t
2: vlan2: 0 8t
56: vlan56: 0t 1t 2t 8t
57: vlan57: 1 2t 5 7t 8u
58: vlan58: 0 2 3 4t 7 8u
59: vlan59: 0t 2t 3t 4 7 8t
60: vlan60: 1t 3 4 5t 7t 8u
61: vlan61: 2 3 4 8u
62: vlan62: 1 2t 5t 8t
robocfg result from older firmware:
1: vlan1: 1 2 3 4 5t
2: vlan2: 0 5
56: vlan56: 0t 1 2t 8t
59: vlan59: 0t 3t 7 8t
60: vlan60: 1t 3 4 5 7t 8u
2: vlan2: 0 8t
2: vlan2: 0 5
I think if CTF is DISABLED, the CPU port changes from 8t to 5t ???
