Hi all new to this forum Im using an Asus RT-AX88U on the latest merlin firmware and I am wishing to just reroute only the router IP trafiic 192.168.50.1 via VPN and have the rest of the devices via WAN.
I have performed a bit of research and as I understand this is not possible via the GUI using VPN Director in conjunction with an ovpn client.
I have tried various methods via SSH and it appears to do with the overiding of routing in the local table which is referenced in Rule 0.
Has anyone been able to successully use selective policy routing for just the router address itself or is this not possible, if anyone has had success would you mind sharing your steps, thank you.
Kind Regards
CG
Kind Regards
CG
