amtm installed yazfi then reboot it and lost yazfi/flexQS/amtm
lalord69
I installed yazfi then set it up thru the GUI then rebooted and now FLEXQS/DIVERSION/AMTM not loading or working.
i uninstalled yazfi but it did not fix anything. dont have any amtm scrips--how do i get everything back?
AX3000 on 384.19
part of the log
Jan 23 11:20:16 kernel: ubi2: attaching mtd10
Jan 23 11:20:16 kernel: ubi2: scanning is finished
Jan 23 11:20:16 kernel: ubi2: attached mtd10 (name "misc1", size 8 MiB)
Jan 23 11:20:16 kernel: ubi2: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Jan 23 11:20:16 kernel: ubi2: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Jan 23 11:20:16 kernel: ubi2: VID header offset: 2048 (aligned 2048), data offset: 4096
Jan 23 11:20:16 kernel: ubi2: good PEBs: 64, bad PEBs: 0, corrupted PEBs: 0
Jan 23 11:20:16 kernel: ubi2: user volume: 1, internal volumes: 1, max. volumes count: 128
Jan 23 11:20:16 kernel: ubi2: max/mean erase counter: 10/4, WL threshold: 4096, image sequence number: 1108767370
Jan 23 11:20:16 kernel: ubi2: available PEBs: 0, total reserved PEBs: 64, PEBs reserved for bad PEB handling: 4
Jan 23 11:20:16 kernel: ubi2: background thread "ubi_bgt2d" started, PID 3024
Jan 23 11:20:17 dnsmasq-dhcp[2379]: DHCPDISCOVER(br0) 00:d0:2d:a0:0b:d3
Jan 23 11:20:17 dnsmasq-dhcp[2379]: DHCPOFFER(br0) 192.168.50.6 00:d0:2d:a0:0b:d3
Jan 23 11:20:17 kernel: UBIFS (ubi2:0): background thread "ubifs_bgt2_0" started, PID 3041
Jan 23 11:20:17 kernel: UBIFS (ubi2:0): UBIFS: mounted UBI device 2, volume 0, name "nvram"
Jan 23 11:20:17 kernel: UBIFS (ubi2:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Jan 23 11:20:17 kernel: UBIFS (ubi2:0): FS size: 5840896 bytes (5 MiB, 46 LEBs), journal size 1396736 bytes (1 MiB, 11 LEBs)
Jan 23 11:20:17 kernel: UBIFS (ubi2:0): reserved for root: 0 bytes (0 KiB)
Jan 23 11:20:17 kernel: UBIFS (ubi2:0): media format: w4/r0 (latest is w4/r0), UUID AF9E64C7-2546-4160-94B7-C0D3AFA3E6D3, small LPT model
Jan 23 11:20:18 kernel: UBIFS (ubi2:0): un-mount UBI device 2
Jan 23 11:20:18 kernel: UBIFS (ubi2:0): background thread "ubifs_bgt2_0" stops
Jan 23 11:20:18 kernel: ubi2: detaching mtd10
Jan 23 11:20:18 kernel: ubi2: mtd10 is detached
so i rebooted again, disabled ALL guest settings then rebooted again then uninstalled yazfi thru ssh then rebooted and now flex/diversion and amtm is working again?
OK. Me too. AX3000. Yes, it is not on the supported list on GitHub, but said what the heck and tried anyway. But same result as above uninstall and reboot solved.
Personally I turned off the unfinished Diversion WebUI beta and some intermittent WebUI mounting issues I had went away, so worth checking.
If not using the Diversion WebUI, to help me troubleshoot the issues you're seeing, please post copies of syslog from a reboot where the tabs didn't appear along with the output of the below command
df -h | grep menuTree
Sorry, but I’m not sure I understand your reply. I think that lalord69 meant he set it up on the Merlin GUI for the ASUS router, which I did also. And I don’t know any df call that would yield anything like menuTree. Mine just shows that diversion is on the usb and mounted.
