AlexanderW77
on my RT-AC68U I'm currently using firmware 380.68_4 and I'm experiencing some problems with my wireless stuff.
My router is configured in wireless router mode and wireless is set to not isolated.
Problem I'm facing for quite some time now is that for some reason connections form wired to wireless or between wireless are not possible anymore.
For example, I have two raspberry pi's, after turning them on initially I can connect to them wireless but then after while it is not working anymore. Reaching them throiugh the internet (port forwarding) is still possible and when in this case I ping my wired host it takes some time afeterwards ping times are ok and wired to wireless is working again also.
Another example is a wireless connected laptop that wants to print to a wireless printer. Sometinmes is works, siometimes not, printer ca not even be pinged fromthe laptopn but can be pinged from the router, the laptop can also be pinged from the router.
Last example, one raspberrypi used as surveillance camera stores data on an nfs export at the router, works nicely and is reliable, but also the pi all of a sudden can not be reached from a wired host anymore , while at the same time the pi still keeps storing data on the nfs share.
In all cases a reboot of the router solves the problems for a few hours to a few days.
What's going on here and most important, how do I solve this?
