intermittent connection issue
Trebuin
Ok, I'm now on .41 and it was working great until I had to pull the power on the ASUS to fix a problem with another system (pulled surge protector plug). For some reason, it works fine for a few hours now then acts as if it has gone offline every now and then. It is acting in repeater mode connected to an Apple TC. Didn't do this in past firmware...probably caused by me. No errors are showing at the time of being in this unstable state. Any thoughts? Already tried resetting everything.
I'm not quite sure yet. But since i moved from .41 to .42 i got complaints from people in my household. Disconnecting traffic, and restart windows solves everything.
Also since i moved from .40 to .41 i have the feeling my wan speed dropped. So i am not able to get full 10mbps up/down.
I think i downgrade this weekend to .40 and see if things will work the same, or better
It's on OSX for me. Just updated to .42 now...issue not resolved. Doing a large update and I see about 15mb download, then stall...then download 15 more...then stall...and so on. Still think it might be self induced.
Sorry, has nothing to do with merlin firmware.
Media convertor fiber-copper, and linksys managed switch reboot solved my problems. I'm back to .42 release
I still haven't figured this out. The AC66R just isn't acting well as a repeater for the TC anymore. I'm about to due a reset default settings on the TC to see if that helps.
