Intermittent Ping Spikes
micahelriley
Hi, I was wondering if someone could explain a few things regarding the data from my DOCSIS WAN report? I'm experiencing some intermittent latency issues with ping spikes tested on different domains, happening every 60sec or so, 200-1000ms. I have a Tech coming here tomorrow and was going to ask if a higher freq. tap was installed to accomodate the docsis 3.1 higher freq 751-845, as I think it's possible this could be related to my issue? As well, should I see one of the two OFMDA channels enabled, both are disabled in the overview chart?
Also noted that the upstream signal levels seem a bit high (41.26 - 42.02), not sure if this is beyond any threshold?
Any insight would be appreciated.
thanks,
Bob.
Downstream Overview
Port IDFrequency (Hz)ModulationSignal strength (dBmV)Channel IDSignal noise ratio (dB)BytesCorrectedsUncorrectables
1603000000QAM256-0.200940.94639373113700
2375000000QAM256-1.299138.98333259148470
3381000000QAM256-1.200240.36633151832400
4387000000QAM256-1.200338.98333665154300
5393000000QAM256-1.299438.98333392111000
6399000000QAM256-1.299538.98333543909300
7405000000QAM256-1.400640.36633187857410
8411000000QAM256-1.500738.98333322022700
9417000000QAM256-1.299838.98333598392200
10609000000QAM2560.2001040.36632961641100
11615000000QAM2560.2991138.98332798662800
12621000000QAM2560.4001240.36633010051800
13627000000QAM2560.5001340.36632825083400
14633000000QAM2560.7001440.36633514827600
15639000000QAM2561.0991540.36631629122200
16645000000QAM2561.2991640.36632632202700
17651000000QAM2561.0991740.36634588898600
18657000000QAM2561.4001840.94635044566700
19663000000QAM2561.4001940.36634730092700
20669000000QAM2561.5002040.94634868487700
21675000000QAM2561.2992140.36636127697000
22681000000QAM2561.2002240.36635320510800
23687000000QAM2561.2002340.36636571023730
24693000000QAM2561.0002440.36634872820200
Reset FEC Counters
OFDM Downstream Overview
ReceiverFFT typeSubcarr 0 Frequency(MHz)PLC lockedNCP lockedMDC1 lockedPLC LocationOccupied BW(MHz)SubcarriersPLC power(dBmv)
0NANANONONONA0 ~ 0NANA
14K695600000YESYESYES1504751 ~ 844.9518400.200001
Upstream Overview
Port IDFrequency (Hz)ModulationSignal strength (dBmV)Channel IDBandwidth
13676800064QAM41.77046400000
23011200064QAM42.02036400000
32345600064QAM42.02026400000
41840000064QAM41.26013200000
OFDMA Overview
Channel IndexStatelin Digital AttDigital AttBW (sc's*fft)Report PowerReport Power1_6FFT Size
0DISABLED0.00000.00000.00000.00000.00002K
1DISABLED0.00000.00000.00000.00000.00002K
What is the vendor/model of the cable modem?
There was/is an issue with certain Intel Puma6 chipsets that a few vendors used for DOCSIS 3.0...
In general you're not seeing a ton of errors which means you're good for signal / SNR.
The OFDMA channels should be engaged though for higher speed plans. If you're on a gig+ plan you should have both of them synced and operating. Now, if the provider doesn't offer gig speeds yet or disabled them in your speed profile for OFDMA that would explain why they're not synced.
Ping spikes are normal periodically but, 1000ms is usually more when the connection is over saturated during a DL / UL not randomly during the day.
I would see if they will run a "homerun" from the NID to the room where the CM is and bypass all splitters to see if things improve. Sometimes there's weird things that happen with splitters over time. Getting them out of the path is ideal. When I had my CM running through a home terminal splitter for the prewired connections I found it hard to hit the plan speed but, when I cut the terminal out of the equation I hit 980+DL / 40UL. When I went DIY and made my own router I got beyond that up to 1200-1500DL speeds by bonding 2 ports through LACP.
If you're paying a monthly fee for the modem look into options you can buy like the MB8600 which is what I was using before going 5G with T-Mobile. I was using it for ~7 years w/o any issues other than when there was a power outage. It's still usable and looks new. There are newer models though that have a single 2.5gbps port on them that seem to be more relevant since more 2.5gbps ports are coming out on the consumer side. Buying one will easily be paid off in a year at $10-$15/mo the CCo is charging for their rental unit.
Hi, my plan is only 350 up/10 dwn, so maybe it's not high enough for the OFDMA channels to be engaged, like you said? As far as splitters there are none from the pole to the modem, it's actually one thing we removed when I had other issues two years ago. I should mention that all the speed tests I've done have had no problems, they usually come within 250-310Mps download and always 10 upload, every test, it's just these random latency spikes I get. This plan includes their modem/router combo., but I did contemplate buying a new one to use in bridge mode. I also let a ping test run today while I was out and the spikes where there every few minutes again, but the range was lower, approx. 150-250ms. Do you think these spikes are normal?
Hi, it's a Hitron CODA 4582
It's PUMA 6 chipset from Intel - it's a problem with the chipset itself...
Intel Puma 6 Defect Explained
Intel’s Puma 6 chipset included in several cable modems is defective as it allows high spikes in network latency quite often (slow web page loading, for example). These severe network latency spikes interfere with online gaming, streaming video, or simply surfing the web. Network jitter (variable latency) also causes problems.
The Puma 6 modems suffer from both latency and jitter. Some firmware updates have only temporarily fixed the problem and it seems Intel has no real fix for the issue. Consequently, these bad internet connections landed cable modem maker ARRIS in trouble with a pending lawsuit filed in California.
If I recall even the Puma 7 was problematic as well. I’d get something like an the MB8600 or Arris SB8200 which is pretty well built (the latter I have used) and both use a BCM 3390 chipset.
Well that would probably explain what I'm seeing, thanks for the info., I'm sure the Tech will replace it. Say the ISP, or Tech. decides not to replace it for some reason, would a new router placed in brdge mode with the Hitron bypass the defective chipset all together? I understand what bridge mode is, but I'm not familiar with how the units work in tandem, or if the Hitron just acts as, lets say a port and is bypassed totally with the bridged unit?
