internet not working on RT-AC66U after flashing with Merlin firmware
RithNV
hello All,
This is my first post, although I have been an ardent follower of this forum.
After careful reading of instructions on the SNB forum, I flashed my router with RT-AC66U_378.56_2.trx version firmware. I had updated this to monitor the bandwidth and data usage on a each ip which is available on the Merlin version.
After couple of (almost two days) iterations, i was only able to set the different fields (although this was already using the existing values) but my internet is now not working even though it shows connected. I get the wireless connections but not the internet. It doesn't work either in the wired or wireless mode.My isp username and pwds are correct.
. Also, i used to use the stock version all this while and it used to work ok except for a few disconnections now and then.
I am attaching the screenshots of the router config.
I use a DLINK wireless modem and it works perfect standalone. when connected with the router, I switch the modem to Bridge mode and router to PPOE mode.
I am not sure what I am missing. Can any one of you please help me ?
Thanks,
Rith
