Internet Status: Check Connection... message
SergioG
This is not for now a major problem, but is a bit confusing:
Although the internet seems to be working fine, since I installed the latest Merlin update for RT-AC66U, the router page constantly shows "Check Connection ..." status. Also, the 3 icons on the upper right corner of the page are now always dimmed (even when Wi-Fi is running). Any suggestions on what may be causing this?
Router RT-AC66U
Firmware Merlin 380.58
S
Sounds like a Javascript error breaking that page. Open your browser console and look for a Javascript error - chances are it's caused by either your SSID or a client device name containing an illegal character.
Thanks for the reply. I actually reseted the settings to default (keeping the last Merlin firmware) and it seems that the issue got fixed now.
