IoT network with different subnet
arsnlgunnr
Hi all,
I created an IoT network via GNP with the separate subnet/VLAN configuartion. When connecting devices to the separate IoT network over wifi, some devices are assigned an IP with the correct subnet and others still maintained an IP belonging to the main network subnet. Is this because I'm using an unmanaged switch?
Current AI Mesh network set up:
RT-BE88U (main)
RT-BE86U x2 (nodes)
-Ethernet backhaul
-Nodes connect to main router via un-managed switch
-firmware: merlin 3006.102.7
TIA!
No. It is likely that you had some of those WIFI clients connected to your main WIFI then switched them to the guest WIFI. It will take some time before the Asus Network Manager wakes up and realizes the IP's for those clients have changed. Rebooting the router may help then again it may not. The DHCP clients on the guest WIFI will get the right IP range address. Check the DHCP leases.
Hi all,
RT-BE88U (main)
RT-BE86U x2 (nodes)
-Ethernet backhaul
TIA!
I would think that a simple switch does not affect DHCP IP address assignments.
Maybe the wireless clients are reflecting the DHCP of the network they are connecting to?
Does it work correctly with stock ASUSWRT firmware?
Does it work if you create your own custom IoT GNP instead of using the built-in IoT network?
OE
