IP ADDRESS assigned to Broadcom BCM47XX
JimH
Noticed in my syslog that my Asus RT-AC3100 includes a Broadcom BCM47XX Ethernet Controller has an IP of 7.14.131.56 assigned to it.
Q:
1. what is the significance of this IP Address (a simple search says it's assigned to DISA).
2. Can/Should this be reconfigured, and if so, how can this be done.
Other than the syslog entry:
kernel fwd0: Broadcom BCM47XX 10/100-1000 Mps Ethernet Controller 7.14.131.56 (r641653)
Nothing related to this entry is noted in the web interface. Thoughts?
Thanks for the update.
Its interesting that after switching over to asuswrt-merlin, these values changed.
Any idea how (given the fact that their versioning numbers)?
Has the controller been updated with the new software?
Jul 31 20:00:14 kernel: fwd0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.4402 (r628786)
Jul 31 20:00:14 kernel: fwd1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.4402 (r628786)
Jul 31 20:00:14 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.4402 (r628786)
JimH
The driver software is constantly being updated, just like any other software. Why would you think it wouldn't change?***
BTW You didn't mention what firmware versions you were running before and after installing Merlin.
*** Edit: Perhaps you were thinking that the BCM47XX "controller" was an independent entity with its own firmware. It's nothing so sophisticated, it's just a chipset and the version number refers to the software driver.
Thanks. your assumption at the end is what I was thinking.
Appreciate the quick response.
JimH
