iptables, chromecast, netflix, tunlr
odiovidio
Alright. I've set up Tunlr according to the wiki for use with Netflix. All of my devices are now able to get US Netflix with one exception: Chromecast.
I found this suggestion on the XDA forums for a possible workaround.
So I tried to copy it for my configuration and used the following:
iptables -t nat -A PREROUTING -d 8.8.8.8 -s 192.168.5.25 -j DNAT --to-destination 192.168.5.1
iptables -t nat -A PREROUTING -d 8.8.4.4 -s 192.168.5.25 -j DNAT --to-destination 192.168.5.1
192.168.5.25 is the chromecast and 192.168.5.1 is my router.
This doesn't seem to work properly. Also, I can't tell if the iptable rules are actually being enforced since doing an
iptables -L -t nat
doesn't show them.
How can i tell if my iptables rules are actually being used? And should this work for the chromecast?
iptables -L -t nat
doesn't show them.
If you add the "-v" flag, you will see how many packets are matched against each rules.
iptables -t nat -L -v
Can someone help me please, just got myself a chromecast so need to do as described above.
I use these rules manually entered from telnet and works fine
iptables -t nat -A PREROUTING -d 8.8.8.8 -j DNAT --to-destination 176.67.84.19
iptables -t nat -A PREROUTING -d 8.8.4.4 -j DNAT --to-destination 178.79.166.52
How can I make these rules survive a reboot of the RT-N66. I've tried adding them to /jffs/scripts/nat-start but doesn't seem to work.
How should I do it ?
Don't forget to put a shebang at the start of your script:
#!/bin/sh
And also to make it executable:
chmod a+rx /jffs/scripts/nat-start
Then, test it manually:
