ipv6 recipe for asuswrt-merlin via hurricane electric
i've set it up with your guide and everything worked out
had some issues with the password part.
but when i choose the tunnelkey as password it worked out.
only issue i got now is that i can't connect to my internal network anymore.
do i need to change something else to make this working again
I have found that sometimes wan-start runs before the wan is ready to go, causing the tunnel update to fail.
I added the following to verify the connection by pinging the HE server between defining the settings and updating the tunnel:
# pause until connection is ready #
#if ping test succeeds, log it and proceed to update tunnel.
if ping -c 1 "$HE_VERIFY_SERVER_IP" &>/dev/null
then
    echo " " >> "$STARTUP_SCRIPT_LOG_FILE"
    echo "Already Connected - $( date )" >> "$STARTUP_SCRIPT_LOG_FILE"
#if ping test failed, pause until connection is ready.
else
    i=0
    while [ $i -le 50 ]
    do
        then
            echo "Now Connected, starting tunnel update - $( date )" >> "$STARTUP_SCRIPT_LOG_FILE"
            break
        fi
        echo >> "$STARTUP_SCRIPT_LOG_FILE"
        echo "Not Connected, - $( date )" >> "$STARTUP_SCRIPT_LOG_FILE"
        echo "connecting wait ..."
        sleep 15
    done
fi
Now the tunnel update on boot is more reliable.
