I want to enable the Smart Connect Rule because, originally set up as effective, it's very functional.I haven't seen the smart connect setting since I upgraded my router. Allegedly it's still accessible via the asus app. It's also possible to disable smart connect through ssh.
Where can I download Asus applications?I must have missed what's going on here... is SC being forced now? Is the app the only way to configure using or not using it?
OE
www.snbforums.com
www.asus.com
I used this app but couldn't find where to set Smart_Connect_Settings.@superflq
ASUS Router App | ASUS UK
Easy network management at your fingertips with enhanced security features. Your ASUS routers are easier than ever to setup with our highly rated mobile Router App. Your seamless WiFi network can be setup within 3 steps with world-class security features like AiProtection, comprehensive...www.asus.com
As was indicated in my other post in another discussion which you replied to, it depends on the firmware version. See the following Asus Support document:Please ask if routers with firmware versions later than 3.0.0.6.102_35404 (including this version) cannot set the Advanced setting for Smart Connect (Smart Connect Rule)
See that Asus link. It explains how to configure Smart Connect based on which Interface one is using. Further it mentions Smart Connect Rule under Interface 2 directions. From that Interface 2 direction:1. Some functions of wireless will be different due to firmware version.
Interface 1: Supports routers with firmware later than 3.0.0.6.102_35404 (including), please refer to here for the setting instructions.
Interface 2: Supports routers with firmware earlier than 3.0.0.6.102_35404, please refer to here for the setting instructions.
Note: The built-in WiFi network preferences settings on a mobile device may render the smart connect rule ineffective or lead to frequent disconnections.
And more from that Asus Support link on Smart Connect Rule:Interface 2: Supports routers with firmware earlier than 3.0.0.6.102_35404
C. Advanced setting for Smart Connect(Smart Connect Rule)
ASUS Router comes with a default trigger condition setting for the Smart Connect switching mechanism. However, depending on your networking environment, you may need to customize the trigger condition. To do this, navigate to the Smart Connect Rule page in Network Tools or simply click the Smart Connect Rule link in Wireless General.
Note: Some models do not support the advanced settings of Smart Connect. If you do not see [Smart Connect Rules] when activating Smart Connect, which means your model does not support it.
1. How to reset Smart Connect to its default settings?
3. Why I can't see the advanced settings of Smart Connect (Smart connect rule) in ASUS Router APP and ExpertWiFi App?
The Router APP do not support Advanced settings of Smart Connect (Smart connect rule ), which is only available in Web GUI.
thanks youAs was indicated in my other post in another discussion which you replied to, it depends on the firmware version. See the following Asus Support document:
From that Asus Support link:
The biggest problem is that the 5.8G Wi-Fi connection has poor performance and fails to automatically switch to the 2.4G network.As was indicated in my other post in another discussion which you replied to, it depends on the firmware version. See the following Asus Support document:
We use essential cookies to make this site work, and optional cookies to enhance your experience.
