Is the RT-BE88U the successor to the RT-AX88U?
Fringe09
Hi everyone, I’ve been looking at the RT-BE88U and wondering if this is essentially the next generation of the AX88U line.
Can anyone confirm if the RT-BE88U is positioned as the successor to the RT-AX88U? They seem to share similar design philosophy with the 8 LAN ports, but I want to make sure I’m looking at the right upgrade path.
Any insights would be appreciated!
Yes, to me it was. Exact same form factor as my old ax88u. One thing to bear in mind - this router can't do 6GHz. It's a hardware limitation.
It depends on what you want to upgrade. RT-BE88U will give you newer hardware with faster WAN/LAN ports and new firmware with VLAN features, but Wi-Fi speeds will remain about the same. It's a dual-band model and the same 2.4GHz/5GHz band limitations apply.
