Is this switch set-up reasonable?
Feldon
Basic VLAN type question here...
Start with an 8-port managed switch (ex. Cisco SG200-08P).
Connect a few wireless AP's with "guest" and "staff" SSID's.
Connect an unmanaged switch feeding several staff-only computers/devices.
Assuming I want to keep the guest and staff networks separate...
Questions:
1. I assume I have to choose whether the unmanaged switch is connected as a guest or staff network device?
2. I assume all of the wireless AP's have to be connected to the managed switch in order to allow have them directed to the guest and staff networks?
Questions:
1. Yes
2. Yes
There are some AP's that can run an isolated guest network without VLAN's but best practice is to use VLANs.
A dumb switch will strip VLAN tags so you need to keep a dumb switch contained to one VLAN.
A dumb switch does not strip vlan tags. If a tagged vlan gets to a switch with no vlan configuration, that tagged vlan will pass around normally but all the ports on that switch can use that tagged vlan. Even if the switch was managed it will still pass the vlan unless it has a configuration in place to handle it.
To terminate a tagged vlan you do not use a dumb switch, you use a router/managed switch to terminate it by setting it to passive/untagged or an end client(uncommon).
I would recommend getting two switches that support VLANs, not one. It's not going to save you tons of money to go unmanaged, and as your needs change (and they usually do, you're probably going to wish you had at some point. You're likely to avoid hassle that way, and your time is worth money too.
It's always good to plan long term.
