Isolate LAN device from other devices
Shino
I want to isolate a device connected to LAN from other devices, but the AX86U GUI does not have this feature. I noticed that there is a way to use ebtables, but it doesn't seem to work?
ebtables -A FORWARD -i eth1 -o br0 -j DROP
Sounds like you want VLAN. Do a search for VLAN to find some past discussion on various attempts to create VLAN's to isolate wired LAN clients. Example:
https://www.snbforums.com/search/1238102/?q=vlan&o=relevance
https://www.snbforums.com/search/1238100/?q=vlan&t=post&c[child_nodes]=1&c[nodes][0]=42&o=relevance
If one has a WRT5.0 3006.x supported Asus router they can try Guest Network Pro/VLAN feature found in the 3006.x firmware.
I know VLAN can achieve this feature, but AX86U does not provide it. I just need to isolate the devices, so I hope the method is as simple as possible.
Per the search links previous provided is the following discussion on using VLAN's on non Pro series routers:
