Isolating XAVB5001
headrat
So I'm using the XAVB5001 successfully upstairs on one ring main, the problem I've got is when I plug in an adapter downstairs it tries try and connect to the ones upstairs and the throughput is terrible.
Lounge (Ring 1)
XAVB5001 (Lounge, wired connection)
XAVB5001 (Lounge, XAVB5001 plugged in to other site of room)
Upstairs (Ring 2)
XAVB5001 (Bedroom 1, wired connection)
XAVB5001 (Bedroom 1, XAVB5001 plugged in to other site of room)
XAVB5001 (Bedroom2)
XAVB5001(Bedroom 3)
is there any way to logically separate the adapters so they can't see each other over the house wiring.
I basically want Lounge/Upstairs not to "see" each other, I've got wiring to facilitate the communication between upstairs and the downstairs lounge.
Thanks HEADRAT
For some reason the encryption key didn't take first time, I've now reset the key and it's all working fine.
Getting between 20/25MBps (160/200Mbps) real world so more than enough to stream multiple 1080p MKVs :)
HEADRAT
To be clear, the XAVB5001 is not a device. Rather, the XAVB5001 is a kit with two XAV5001 adaptors... right?
