Skynet Issue with Onedrive
Goned75
I have issues with Skynet and Onedrive.
When Skynet is enable - I'm not able to connect to onedrive.
When I disable Skynet - Onedrive is ok.
Anyone have this issue too ?
Thanks,
Regards,
I had...
I finally decided to remove Skynet, in the last months the numbers of false negative raised to an alarming rate. Every week a lot of legitimate websites was blocked.
Now I only use unbound with urlhaus and the default trendmicro protection.
Thanks,
Regards,
I had...
Do you get any firewall stats in unbound? I have been using Skynet and also enabled firewall in unbound. So far all the counts are logged in Skynet and nothing in unbound DNS firewall. Perhaps Skynet takes precedence?
Well I haven't enabled the unbound logging features so I don't know.
If I try to connect to some blacklisted sites the connection fails,, so I think it works ;-)
