Issue with VPN Connectivity
macster2075
I am on the latest firmware version, and I noticed my vpn wasn't connecting, but I still have Internet even though the kill switch is enabled.
My question is, if the vpn stopped connecting for whatever reason, why didn't the kill switch kill the connection?
I thought the reason for the kill switch is to keep me protected when the vpn disconnects.
Any ideas?
That's true, but you need to have a working VPN for it to "disconnect". It looks like you don't have a valid VPN profile.
Yeah, I found out that specific server I was using was discontinued by my vpn provider. Are you saying that if it just stops working instead of getting disconnected, the kill switch won't work as it should?
That doesn't seem logical to me. If there's no VPN connection for whatever reason, the kill switch should just stop all connections, no?
This was explained by RMerlin in the past. Basically, there's a difference between a VPN client that's deliberately turned off or not configured (correctly), and a working VPN client that disconnects. The router can't guess what the user's intention was in the former case with regards to any killswitch action. RMerlin got fed up with people complaining about this, half the people wanted the killswitch to work one way and the other half another way. In the end he made his decision and that's the way it is.
oh wow. Didn't know this was an issue like that lol. Ok it is what it is then. Now, is there a way for me to block internet connection when the vpn stops working for ANY reason or even if I disable it?
Maybe via script?
I can't imagine why would anyone would want the connection to persist when the vpn stops working for any reason other than disconnect. In that case, then don't use the kill switch.
As I said, you can create a VPN client profile that doesn't work that just happens to have the killswitch option enabled (among many other options). As the profile as a whole is invalid the router can't guess what your intention was.
Right, I understand what you're saying. I just don't see the reason for the router to have to "know my intention" to do what I told it to do, which was to kill the connection when the vpn is enabled, but not connecting for any reason. In my mind, it makes perfect sense lol.
Can this be done by script?
I ask because you mentioned that Merlin decided to set it this way, which makes me think there IS an option to use the kill switch how I would like for it to work.
@ColinTaylor - How do I uninstall custom scripts?
It depends how you installed them. If you manually created a new file, delete that file. If you added lines to an existing script, edit that file and remove those lines. If you used a third-party script that had its own installer then you need to refer to that script's documentation for the uninstall procedure.
Thank you..it's the one from eibgrad
I went to the page but I don't see uninstall instructions. I also asked eibgrad, but he hasn't responded yet. I see he hasn't posted any comments on that page since April.
It looks like you will have to manually remove it.
First delete the main script:
rm /jffs/scripts/merlin-ovpn-client-killswitch.sh
Then edit the firewall-start script and remove the lines that were added. You'll have to work that out for yourself as I've never used this add-on:
nano /jffs/scripts/firewall-start
After that reboot the router.
Sorry Colin, one more thing.. in the event I have more lines in the firewall.. do I only have to delete this line?
All 5 of those lines are added by the installer script. However, if there is a preexisting firewall-start script the installer doesn't change that file and tells you to edit the file manually. In which case you would know what the file looked like before you edited it.
