Issues with Sonos since the latest update
Came across this thread yesterday and had to write about a similiar problem I have had for the past 6 months with my Sonos speakers (Ikea symfonisk)
I have narrowed down the problem to be a problem for my speakers to correctly reply to a dhcp offer.
I can see the problem in systemlog and even with tcpdump that the speakers correctly sends a DHCPDISCOVER and my router sends a DHCPOFFER but no DHCPREQUEST is ever sent from the speakers.
Instead the speakers resends another DHCPDISCOVER and router another DHCPOFFER in an endless loop. It’s like the offer never reaches the speakers.
My workaround for this problem was to setup a secondary dhcp server on a pc on the network to handle dhcp request for the speakers. It works great now but thats not how I want things to be. I would like the router to handle all dhcp requests offcourse.
And the sonos speakers are the only dhcp clients that have this problem.
Anyway when I came across this thread I tested to disable my two guest networks I have and BAM! The speakers reply to the routers dhcp offer.
This is so strange. There must be some setting somewhere that could fix this.
And by the way I have a BE86U router with guest network pro enabled with one guest network and a iot network. And I also should say that the speakers work fine with dhcp when connected to the iot network it’s only problem with the main network when guestnetworks are enabled.
Thanks for this @Jom76
So wait, are you saying that the speakers are requesting a DHCP address, the router is responding before the Sonos Arc has a chance. The Arc is expecting the Sonos speakers but is getting a offer from the router and can't translate it and then everything goes in an endless loop? So the router is responding before the Sonos has a chance
As an update, I have been working with Asus support HQ in Taiwan since August and we have narrowed it down to the VLAN feature which i activated as part of the guest network pro feature. If you enable guest network pro, even with the Wifi radio off, it kicks the Sonos off the Sonos private network and you loose access to the connected speakers such as the surrounds and sub. If you enable the Guest Network Pro feature in IOT mode with "use same subnet as main network enabled", then everything works as expected. They have now requsted I reach out to Sonos directly, which I am doing.
Reading thru the tread, I got confirmation that it's better to leave SONOS on their own SONOSnet networking - not adding it into my WLAN - never had issues since 10+ years with many (Asus) routers and regular Merlin-FW updates!
That is true but the newer speakers such as ERA300's don't support SONOSnet as they are working to get rid of it, so that isn't an option
I'm not familliar with the Sonos Arc and Eras 300, I don't known how they connect network wise. I have the IKEA Symfonisk speaker lamp, which is a Sonos speaker.
And those speakers connect directly to my wifi and ask for an IP Adress from the DHCP server. I don't think it's a timing issue that's causing the endless loop for me.
I have tried the past months to figure out what's causing the speakers not acccepting the DHCP servers OFFER broadcast.
But when I saw this thread and that
you had problems with sonos speakers with guest network enabled I tried to disable my guest networks. And that resultet in that my DHCP problems went away.
So perhaps we have a common problem here due to the fact that we both have sonos speakers and problem with guest network pro, maybe it's the vlan thing.
But as I said I don't know how Sonos arc and eras 300 connect to wifi, if it's by direct connection or by some bridging. I don't know.
Could be some common issue here I think.
Hi All
I have the same issues with sonos beam2 and era100.
I make some test for other needs, with 3.0.0.4 firmware i was able to use dnsmasq as dhcp-relai, i edited config to serve multiple dhcp subnet.
but with 3.0.0.6 firmware this don't work anymore, it look like it doesn't received the dhcp query from some device.
I suspect a change on filtering rule, that impact also bridge behind wifi.
When i connect the sonos beam via ethernet, i dont have issues.
Having the exact same issue with my Symfonisk speaker not accepting DCHP and it has been driving me insane. Is there any new info on a definitive fix other than using an external DCHP server or turning off guest network?
So Asus HQ have logged the issue; however, require assistance from SONOS to push a fix. I have also logged a case with SONOS but their support don't contact customers when working on cases, so I am in the dark on that front. I got feedback from Asus today saying that they are also going to reach out to SONOS via other channels. If you have time, please also log a case with SONOS so that we can get a fix.
Another temp work around is to create a new guest network under guest network pro but select the IoT network and then select "Use same subnet as main network". This works; however, you are obviously allowing your guest network to be on the same subnet.
When you add ERA 300's and the Sub to the Arc in a Home Theatre configuration the Arc creates its own dedicated 5GHz network which the surround speakers connect to. When guest network pro is enabled, it messes with the DORA somehow and breaks this.
So I received a beta firmware from ASUS yesterday. If anyone who would like to test it, please let me know.
Thanks for the heads up, unfortunately your proposed workaround also doesn't work. I am still getting a loop of DHCPDISCOVER and DHCPOFFER and the speaker doesnt get an IP.
Thanks for this thread, exactly the issue I'm having which has caused weeks of grief with Sonos 2nd tier support. Your suggested workaround is working for me at the moment.
Did this beta patch fix the issue?
Thanks a ton for this thread and the work everyone put in. I’ve been troubleshooting this independently on my BQ16 Pro. I’ve wondered why this issue wasn’t highlighted more but if it’s just users that are running a 2nd WiFi network that’s on an isolated VLAN that explains why it’s a more limited impact. I disabled the guest WiFi network (still have the iot network enabled) and the Sonos system seems to be holding on for the minute.
Hi All
I bought the sonos beam2 recently even though I have problem with symfonisk speakers. I thought that worst case is that I have to use my secondary dhcp server for the beam also. But to my suprise the beam worked perfectly with the routers builtin dhcp server.
With IoT, if you share the Subnet then it works fine.
Hi all
So I tested the firmware for 24 hours and it worked perfectly and the SONOS no longer disconnected. Asus said they are going to release the patch as part of their next firmware update. When I asked them what they issue was, they replied with:
Q1: Out of curiosity, could you please let me know what the issue with the firmware was?
ASUS made adjustments related to the UDP Checksum in the beta firmware, and we are pleased that this resolved the customer's issue.
If you still want to test it, please let me know in a DM. I tested it on a RT-AX88U Pro with 4x ZenWifi Mini XD4 Mesh Nodes.
Thanks to the info from @remsta I came up with another workaround that I will test for the coming days.
If you SSH into the router and issue the following command my Sonos speakers can communicate with the routers DHCP server again.
ethtool -K br0 tx off
I put the command in the script /jffs/scripts/services-start to survive reboots. And for now it works perfectly.
According to chat-gpt and some googling this command disables nic/hardware calculation of tcp and udp packet checksums and lets the router cpu handle it instead. I'm not 100% sure what impact this has on overall performance so use it at your own risk.
I figure if this workaround is stable I will use this workaround until Asus releases their fix and the update makes it to the merlin firmware.
this was driving me crazy until I found this thread..
I have beam gen2 + 2x Era 100 surrounds andI also updated my rt-86u-pro from 3004 to 3005.102.5 and started immediately with the guest WiFi features..
everything was working smoothly until I noticed my surrounds were disconnecting from the beam.
I tried everything until I found this thread, disabled the guest WiFi and bam! everything working without any issue..
I think I will disable the guest WiFi until this is properly fixed in the merlin firmware.
thanks a lot @remsta for debugging this issue to the core!
@calex I am happy I was able to help you - it has truly been a pain. Let's hope they release the firmware soon!
