/jffs/scripts not executed at boot am I missing something
speedbump
I am running n66u with the 3.0.0.4.374.35_4-sdk5 build.
I added jffs and formatted it
created /jffs/scripts/services-start
with:
#!/bin/sh
echo "server=/netflix.com/208.122.23.22" >> /tmp/etc/dnsmasq.conf
echo "server=/netflix.com/208.122.23.23" >> /tmp/etc/dnsmasq.conf
killall dnsmasq
dnsmasq -c 1500 --log-async -n
made it executable
and if I manually run it "/jffs/scripts/services-start" it works
if I reboot the router the file is NOT auto executed.
am I missing something ?
if I reboot the router the file is NOT auto executed. am I missing something?
It probably IS running. Add some delay by adding this
#!/bin/sh
sleep 10
There is an even simpler way to add to dnsmasq.conf:
Create /jffs/configs/dnsmasq.conf.add
and fill in:
address=/netflix.com/208.122.23.22
address=/netflix.com/208.122.23.23
No need to make it executable.
Then restart dnsmasq to make the rules effective without reboot
service restart_dnsmasq
and fill in:
I get 404 age not found ... when I go to netflix
Netflix needs more than the two IP's. Just tested it from Switzerland. If I add only the two IP Adresses it will partially timeout.
Where are you located?
Where did you get the IP's from?
I assumed those are DNS ip, so the ones that I am using are Smart DNS.
when I use them in the services-start script they work if I run the script manually, the only problem I am having with the services-start script is that it does not auto run on boot.
Those are Voxel Dot Net's Addresses in New York. Not sure this is working.
Are you using Netflix through a browser?
yes browser,
the Ip's I am using are actually smart dns
echo "server=/netflix.com/21.23.43.50" >> /tmp/etc/dnsmasq.conf
echo "server=/netflix.com/54.229.171.243" >> /tmp/etc/dnsmasq.conf
Use Firefox and install Extension (add-on)
Media Hint
that's not a good solution for me, as I need to have this working on multiple devices/computers.
The services-start script would be great if it would auto start.
I see.
Your script in the first post probably never worked for you as
server=/netflix.com/208.122.23.22 is an invalid descriptor on the router.
You need to use address=/netflix.com/208.122.23.22
Have you used Netflix with these IP's successfully? I.E. did your script work when you ran it manually as said in first post?
I see.
when I wrote the initial post, I just copied the script from another post
my script is like this:
#!/bin/sh
sleep 10
killall dnsmasq
when I created the dnsmasq.conf.add I used:
Yeah, it only works with the address= in the newer firmwares, as I understand it. If you use the dnsmasq.conf.add script and reboot the Router, clear Browser Cache and Windows DNS Cache does it work then? You may need to use different IP's from CDN though.
