Jffs2
bugmenotplz
I recently upgraded my RT-N66U to 374.40 and since then my JFFS partition won't mount automatically on boot (I've rebooted 5 or so times) which is breaking my dnsmasq configuration.
'nvram show' includes
jffs2_on=1
jffs2_exec=
jffs2_size=6291456
jffs2_format=0
I can manually mount it using the command 'mount -t jffs2 /dev/mtdblock4 /jffs' and my files are all there. I just can't get it to mount on boot.
Nothing in dmesg besides
Creating 5 MTD partitions on "Physically mapped flash":
0x00000000-0x00040000 : "pmon"
0x00040000-0x01fe0000 : "linux"
0x001757f0-0x01a00000 : "rootfs"
0x01fe0000-0x02000000 : "nvram"
0x01a60000-0x01fe0000 : "jffs2"
Suggestions? I've manually copied the file in and restarted the service so it's not urgent, just annoying :)
jffs2_on=1
jffs2_exec=
jffs2_size=6291456
jffs2_format=0
Try clearing the size setting and rebooting.
nvram unset jffs2_size
nvram commit
reboot
