LAN speeds much faster than my spdMerlin results?
iamnick
Hey guys, I'm having a weird issue with spdMerlin's results. I'm having some speed inconsistencies between WIFI and LAN, so I've been running the tool when I make tweaks. The results don't make sense to me, and I'm hoping someone here can help me.
My setup:
ATT 1gbps fiber => Arris BGW210-700 => (IP Passthrough to WAN Port) => RT-AC3100
RT-AC3100 operation mode is 'wireless router', and the WAN IP shows that it's connected to a public IP. Devices connecting to the router are using assigned IP's of 192.168.2.*
I'm able to run the speed test inside the diagnostics of the BGW which gives me these results over the last couple days:
Test Completion Time
Direction Throughput(Mbps) Overhead Average Latency(ms)
03/10/2020 18:39:39 downstream 976.073 70 13.325
03/10/2020 18:39:28 upstream 896.708 70 2.588
03/09/2020 21:27:47 downstream 976.073 70 3.053
03/09/2020 21:27:36 upstream 896.684 70 2.42
03/08/2020 15:00:28 downstream 974.126 70 3.073
03/08/2020 15:00:17 upstream 895.031 70 9.924
03/08/2020 00:31:11 downstream 976.073 70 6.686
03/08/2020 00:31:00 upstream 897.167 70 10.308
Thanks to spdMerlin, I am able to run the speed test directly on my RT-AC3100:
Time Download (Mbps) Upload (Mbps)
2020-03-10 18:37:00 543.79 486.98
2020-03-09 23:44:46 545.05 473.41
2020-03-09 23:42:28 536.04 430.5
2020-03-09 23:38:14 537.32 438.56
2020-03-09 22:22:30 544.08 456.27
2020-03-09 22:09:57 534.83 482.73
2020-03-08 15:05:07 537.93 510.02
2020-03-08 14:12:23 538.18 455.58
2020-03-08 13:42:21 535.89 507.22
2020-03-08 13:12:28 539.47 487.26
Here's the kicker, when I plug my laptop(ASUS OH102 Network Adapter) into the first LAN port of the RT-AC3100, the speed tests on the laptop match the output results of the BGW. When using the same laptop on WIFI(IEEE 802.11a/b/g/n/ac, 2.4 / 5 GHz 2 x 2 MIMO) the results match the results I'm getting from spdMerlin. Shouldn't my LAN speeds match the speeds given by spdMerlin?
Thanks,
