amtm LED control resets after reboot
iTyPsIDg
Title pretty much says it all. After nearly every reboot, my dynamic LED control resets to off. When I turn it back on, it is then static. So, after a reboot I need to turn LED control back on and set it back to dynamic manually.
Mine gets triggered from the post-mount script after the USB is mounted.
Look for amtm messages in the routers syslog for Entware and LED control messages.
It might be that the USB drive is not correctly recognized. If dynamic LEDs are enabled and the file /opt/bin/opkg is not found, it will disable LED control as it is unable to retrieve the on/off times due to lack of necessary Entware packages to do this task.
I'll check after another reboot because the log entries are already gone.
