LED scripts in Asus DDWRT routers
Marin
Hi everyone,
I just flashed my Asus RT-AC5300 with DDWRT firmware and it is working very well. However, for some reason the WAN light remains red (as if there is no connection). This is not a big deal as the other lights work well but I have read that you can run scripts in the Command section that could change the behaviors, colors of these lights. I have good connection speeds and have been researching the LED scripts page in DDWRT Wiki but have not come across anything that would help change this light from solid RED to WHITE like it normally works with stock firmware. Do any of you have any command scripts to use in this case? Also, do you have any good links/others posts you could refer me to regarding LED scripts for Asus routers so I can further research this?
Thank you very much!
