Lg-nas n4b1
bnborg
Lg-NAS N4B1 with 4 x 2TB drives
I have been trying some things with my LG-NAS but I seem to have made things worse.
I takes hours to boot, spending most of the time on "Checking quotas", as reported on the front panel display. Not only that, I can no longer access the web interface. IE just sits at "waiting for http://lg-nas...".
I had decided to start fresh so I reinstalled using the original CD and only one two TB drive. Then I upgraded to the latest "firmware". It's not really firmware since it resides on and boots from the hard disk(s). I then took the NAS offline and mounted the drive on Windows using Ext2fsd. This was so I could edit rcS and enable telnetd and root access, which I did.
Following that, I reinstalled the drive and booted the NAS, and finished configuring it. I inserted three more 2 TB drives and configured the user space for one RAID5 array, which ends up being 5.36 TB, as reported by Windows. It took more than a day to build and synchronize the RAID. After that, the problems showed up, yet I can access the RAID remotely using smb, nfs, or ftp.
net use
New connections will be remembered.
Status Local Remote Network
L: \\LG-NAS\Borg Microsoft Windows Network
N: \\lg-nas\mnt\fs\Vol1 NFS Network
The command completed successfully.
I can also telnet to the box:
[root@LG-NAS:~ ] $ uname -a
Linux LG-NAS 2.6.22.7 #3 Tue Nov 3 09:14:31 KST 2009 armv5tejl unknown
[root@LG-NAS:~ ] $ mount
rootfs on / type rootfs (rw)
/dev/root on / type ext3 (rw,data=ordered)
none on /sys type sysfs (rw)
proc on /proc type proc (rw)
none on /proc/bus/usb type usbfs (rw)
devpts on /dev/pts type devpts (rw)
tmp on /usr/local/samba/var type tmpfs (rw)
/dev/md2 on /mnt/fs/Vol1 type ext3 (rw,noatime,data=writeback,usrquota,grpquota)
nfsd on /proc/fs/nfsd type nfsd (rw)
/dev/sr0 on /mnt/cdrom type iso9660 (ro)
[root@LG-NAS:~ ] $ exportfs
/mnt/fs/Vol1 <world>
[root@LG-NAS:~ ] $
I tried restarting apache using the commands I found in rcS, but it didn't help. Rebooting doesn't help either.
Does anyone have any ideas? Is 4 x 2TB drives just too much for this processor? Or does telnetd add too much overhead? It's been almost twenty years since I used much unix. :confused:
Later, I am copying around 100 GB to the array. Network utilization is around 10% on the gigabit NIC, or 12 MB/s = 100 Mb/s. This seems reasonable since my previous copies were much slower. After a couple hours, the LG-NAS finally presented its login web page. I filled in the blanks and hit the button. It sat blank waiting for the web menu from the nas. When it finally responded, it was the timeout logout message. :rolleyes:
This is beginning to suck. I still have no web access. :(
I just wish I remembered more Unix. I'm relearning it all over again. :rolleyes:
I'm also learning the specifics of BusyBox, also Windows Subsystem for Unix Applications although neither one is Unix nor Linux.
At least I can telnet to it. So I telneted to it while I had connected a one TB eSata drive, which had been formatted ext2 by my Dish Network 722k. It has 3 partitions, 1 GB, 500 GB and the remaining 450 GB. The NAS automounted the first partition on /mnt/Removable_ESATA_Vol1.
I mounted partitions 2 and 3 on unused existing directories, /mnt/fs/Vol2 and /mnt/fs/Vol3. Now I am using cp to copy the contents of 2 and 3 to the RAID 5 array, /mnt/fs/Vol1. I guess I don't get to see the progress because it seems hung. But I see the free space decreasing in Windows so it must be working. It sure seems slow, but it is almost a TeraByte since the drive is full.
I welcome any suggestions anyone has. :)
Ok I decided to start over, not the whole initialize but just the user RAID.
I shut it down from a telnet prompt, since the web still times out before it can display the page.
Now I have pulled three of the drives and re-started. It booted a lot quicker. I'll see how the web interface works.
No good. The web page is still not loading.
Have you contacted LG support?
I did once, when I first had the box. They were about useless. I have seen that the poor U.S. support has been noted in the reviews.
Maybe they are better now. Somehow I doubt it. They still do not have any user forums. SmallNetBuilder was the closest I found.
The last "firmware" release was July 2010, but a lot of the executables were compiled in 2007 or earlier, some as old as 2000. :rolleyes:
Yeah. I figured they haven't improved much. But it was worth a shot.
I just thought I'd post an update.
I went ahead and re-initialized it by booting the setup disk that came with it. I updated the "firmware", rebooted, and then shut it down and removed one drive. I edited rcS to enable su and telnetd. I started up the lg-nas with just that drive and then added the other three, one at a time.
After that, I told it to build a RAID5 out of all four drives. Again, it came up with 5.36 TB and said resyncing. After a day and a half it was done. And all the files I had copied to it were back!
It is now reasonably responsive and the web interface works fine. There must have been something corrupt before.
hey i know its been several years but do you still have that cd? i am looking for one and can paypal.
