Limiting Time (hours per day) is it possible?
simon_g
Hi
Is it at all possible to limit not just the hours within a day a device can access but the number of hours as well
for example i want my kids to have access to the PC's for 9am - 9pm but I only want them having 2 hours during that timeframe
this would be killer for me :)
Hi
You might need to setup a separate router double NATed behind your primary router with hotspot software loaded on it like they use in coffee shops where they sell internet access. This type software used to be available to run on routers running DD-WRT. Look at the Wiki for DD-WRT.
The setup would be that you would sell 2 hours of service daily to your children. To cut the internet off at night you would just set the router to turn the radios off at 9 PM. If that doesn't kill the kid's connection plug the router into a lamp timer set to power off the router at 9 PM.
No, 'fraid not.
I think the GUI do not allow for this... But... Could it not be something with a cron-job running e.g. once every hour, a script parsing syslog entries (need some logging of ip addresses or mac-addresses?) followed by a rule-based decision to change iptables-rules? Just thinking - theoretically...
If you are looking to limit bandwidth, that is reasonably easy.
If you are looking to limit access, like with stubborn children or free WiFi, that is not so easy.
Some routers offer a feature called "Captive Portal" which may offer what you want.
you could do it for wi-fi connections by using the built-in scheduler (Professional tab in Wifi) to only have the radio on during certain times of the day. or you could maybe just set the PC to be on a scheduled guest network if you really need both bands of your router for other devices. i'm not aware of any possibility to do this for wired connections on consumer-grade routers.
you could just buy a wireless NIC for the PC and remove the cable, or just disable the wired NIC from the Device Manager or Network and Sharing Center (assuming you use Windows). if you have a regular User account for your children then they won't be able to enable it. i think this solution would be cheaper than buying a professional switch.
Did this ever go anywhere? I'd like something like this for my kids too!
I started something and now have a simple 2 hour limit per day for the XBox One, however it's all in 1 hit, so when the XBox turns on the clock starts, and anything outside that requires me to unblock the XBox manually. I plan on modifying my scripts to do just what you're looking for... when I find time!
Cheers
Cheers
Only thing I can think of is the AIprotection time scheduling feature. Have a look at that and see if it would work for you or not.
Thanks, but no, it's not working for me. I'll continue to develop my scripts. I have a straight 2 hour limit that kicks in when the XBox is turned on, but need to make it more flexible to allow say 2 x 1 hour blocks within the day. I think it'll be achievable... just need to find the time.
Ah ok, yea sounds like you want something with a little more customization. Would be interested in seeing your script once your finished. I have kids that I would love to use this on now that school has started. ;) I've use the time schedule to make sure the oldest doesn't continue to watch tv or play games late at night. :mad:
Take a look see under "guest". It allows you to impose time limits (like 2 hours). I do not know if it's robust enough for your needs.
Hi
Take a look at "Norton Family".
Time supervision allows specification of blocked hours of the day and can alert (limit?) if number of hours used exceeds what you specify the number of hours allowed hours by day.
Sent using Tapatalk
Hi Quicksilver,
I've got something rough working:
admin@RT-AC86U:/jffs/scripts/xbox# cat xboxcheck.sh
#!/bin/sh
#default state is xbox is blocked. Add this to init-start script
#4am cron to clear xbox flag
#see /jffs/scripts/init-start
maxtime=7300
#If daily flag set. No more checking.
if [ -f /jffs/scripts/xbox/xboxdailyflag ]
then
exit
fi
#Tiime of Day Restrictions
#dow = day of week. 1=Monday - 7=Sunday
dow=`date +%u`
#hod = hour of day.
hod=`date +%k`
if [ $dow -le 5 ]
then
#Weekday
maxtime=3700
if [ $hod -lt 15 ]
then
#Quit out if before 16:00. Not going to continue running, so no xbox
exit
fi
if [ $hod -ge 20 ]
then
#End of the day. Block the xbox
/jffs/scripts/xbox/xboxstop.sh
touch /jffs/scripts/xbox/xboxdailyflag
fi
fi
if [ `wl -i eth5 assoclist | grep "C0:33:5E:D3:17:54" | wc -l` -eq 1 ]
then
#If XBOX ON, increment seconds counter (in a file). Reset file to 0 each night.
#read previous time, and add 5 mins (cron job runs every 5 mins)
prevtime=`cat /jffs/scripts/xbox/xboxison`
totaltime=`expr $prevtime + 300`
echo $totaltime > /jffs/scripts/xbox/xboxison
logger XBOX On $totaltime of $maxtime
#if prevtime == 0 then xbox just turned on. Unblock it.
if [ $prevtime -eq 0 ]
then
/jffs/scripts/xbox/xboxstart.sh
fi
#If $totaltime > Maxtime then block xbox
if [ $totaltime -gt $maxtime ]
then
fi
fi
admin@RT-AC86U:/jffs/scripts/xbox# cat xboxstop.sh
#!/bin/sh
logger XBOX blocked
#/usr/sbin/iptables -C FORWARD -m mac --mac-source C0:33:5E:D3:17:54 -j DROP
if [ `iptables -L FORWARD | grep C0:33:5E:D3:17:54 | wc -l` -eq 0 ]
then
logger XBOX Adding iptables
/usr/sbin/iptables -I FORWARD -m mac --mac-source C0:33:5E:D3:17:54 -j DROP
#nvram set MULTIFILTER_MAC=`nvram get MULTIFILTER_MAC`\>C0\:33\:5E\:D3\:17\:54
#nvram set MULTIFILTER_DEVICENAME="`nvram get MULTIFILTER_DEVICENAME`>XboxOne"
#nvram set MULTIFILTER_ENABLE=`nvram get MULTIFILTER_ENABLE`\>2
#nvram commit
fi
admin@RT-AC86U:/jffs/scripts/xbox# cat xboxstart.sh
#!/bin/sh
logger XBOX Unblocked
if [ `iptables -L FORWARD | grep C0:33:5E:D3:17:54 | wc -l` -eq 1 ]
then
logger XBOX Deleting IPTables Entry
#The below command is dodgy AF
#/usr/sbin/iptables -D FORWARD -m mac --mac-source C0:33:5E:D3:17:54 -j DROP
/usr/sbin/iptables -D FORWARD `iptables -L FORWARD --line-numbers | grep "C0:33:5E:D3:17:54" | awk '{print $1}'`
#nvram set MULTIFILTER_MAC=`nvram get MULTIFILTER_MAC | sed 's/>C0:33:5E:D3:17:54//g'`
#nvram set MULTIFILTER_DEVICENAME="`nvram get MULTIFILTER_DEVICENAME | sed 's/>XboxOne//g'`"
#nvram set MULTIFILTER_ENABLE=`nvram get MULTIFILTER_ENABLE | sed 's/>2//'`
#nvram commit
fi
admin@RT-AC86U:/jffs/scripts/xbox# cat xboxreset.sh
#!/bin/sh
#Zero the counter file, clear the daily flag and block the xbox
logger xbox reset
echo 0 > /jffs/scripts/xbox/xboxison
rm -f /jffs/scripts/xbox/xboxdailyflag
Append these to /jffs/scripts/init-start
#Reset the xbox timer
/usr/sbin/cru a resetxbox "30 4 * * * /jffs/scripts/xbox/xboxreset.sh"
#Check XBox every 5 mins
/usr/sbin/cru a checkxbox "*/5 * * * * /jffs/scripts/xbox/xboxcheck.sh"
Not sure you'll make sense of it!!??
Essentially, I have a 1 script to block the xbox, another to unblock, another to check every 5 mins, and a 4th to reset everything in the middle of the night.
If we wish the xbox to to be allowed on the network after it's been blocked for the day, we can use the router GUI (or the app) to block and then unblock the device, because the above scripts do not get reflected in the GUI. The commented out "MULTIFILTER" nvram variables control the blocking and time scheduling from the GUI, and I don't want to go there just yet as we tend to manually block and unblock other devices randomly, so don't want to break this, but it looks like it's do-able.
Hope this works for you - it appears to work for me right now.
Cheers!
Can you post a text file of it?
For your copy and paste ease:
#!/bin/sh
then
 #The below command is dodgy as
 #nvram commit
fi
#!/bin/sh
logger XBOX blocked
then
 #nvram commit
fi
#!/bin/sh
maxtime=7300
then
 exit
fi
#Time of Day Restrictions
dow=`date +%u`
#hod = hour of day.
hod=`date +%k`
if [ $dow -le 5 ]
then
 #Weekday
 maxtime=3700
 if [ $hod -le 15 ]
 then
  #logger xbox too early
  exit
 fi
 if [ $hod -ge 20 ]
 then
 fi
fi
then
 then
 fi
 then
 fi
fi
#!/bin/sh
logger xbox reset
D ipv6 with controld stops working after about 2 hours Asuswrt-Merlin 43
