Link Aggragation on rt ax86s
Olndo Pindaro
Hi all!
I bought an Beelink EQ12 MINI pc with 2 2.5G NIC and I would like to make a dual lan aggregation with my RT Ax86s (with Marlin on top).
Is possible (i want doubling the band)?
Any experencies of use?
suggestion?
Thanks to all.
Olindo
PS: Beelink support give me driver for IEEE 802.3ad but said is not "Steady"
Asus link aggregation is only supported for 2 x 1GbE ports. So it is possible but you would have to run your Beelink's 2.5GbE ports at 1GbE speeds, which would be slower than a single 2.5GbE port.
I have ax86S, the s version doesn't have 2,5G port, but only 1G ports
Unnecessary complication for no benefit. You’ll still get Gigabit only to any single connection. Eventual multi connection >Gigabit has nowhere to go anyway.
