Link Speed (TX rate) is low
Shaul
I'm using Netgear R7000, 5GHz AC1900 (Max 1300)
using Macbook Pro 16' (but same issue seen using Macbook pro 2016 & Ipad pro 10.5)
There was no issue till today - I get only 54Mbps in the link for the 5GHz.
PHY is 802.11ac , RSSI is -36dbm , Noise is -95dbm (80MHZ) so it doesn't seem wireless issue.
I assume its something with the router .
Both 2.4GHz & 5GHz are enabled. Qos is disabled , WMM is unchecked. (reboot didn't help.)
Didn't try factory reset.
Any idea what can be the problem ?
Thanks in advance,
Shaul.
Thanks in advance,
Shaul.
Resolved - WMM must be enabled. (strange..)
Based on the link rate i would guess you have a wireless G client on 2.4 somewhere.
That would not matter if he had WMM disabled that in itself reverts the router back to wireless G standards.
TheLostSwede TP-Link routers are being taken over by botnet General Wi-Fi Discussion 3
