Linksys EA6900 with Asus Merlin
lucassiq
Hi guys, this is my first contact with Asus Merlin and I must say, this is the BEST firmware ever! Congratulations! My next router will be Asus just because of it :)
I have a question about the 'Turning WPS button into a radio on/off toggle'. Where can I find it?
I was able to install the Asus AC68U CFE on my linksys and after that I installed Asus Merlin (again, for the AC68U).
Its performance and stability are much better than any other firmware I tried, but since this router does not have a physical button for turning wifi on and off, everytime it reboots, the wireless is turned off. So I need to restart it again so it is back on :(
I know that this is out of the scope of Asus Merlin, but is there something I could do about it?
Thanks,
Regards
Running Asuswrt-Merlin on a non-Asus router violates multiple licenses. AiCloud, the Tuxera filesystem drivers, the TrendMicro DPI engines - those are only legally licensed to run on Asus routers.
Thanks for the reply RMerlin. My mistake. I'm going back to stock CFE and ddwrt. (and a asus router in the future).
lucassiq,
just add these lines to your /jffs/scripts/init-start script
nvram set btn_wltog_gpio=255
nvram set btn_wifi_toggle=255
nvram set btn_led_gpio=255
nvram set pwr_usb_gpio2=10
nvram set led_pwr_gpio=6
nvram set led_wps_gpio=8
nvram set led_usb_gpio=255
nvram set led_usb3_gpio=255
nvram set led_5g_gpio=255
nvram set led_turbo_gpio=255
