Linksys EA9200 Throughput Help
Just Mark
I have used this router for a year or so as the gateway to my internet service without issue. I recently upgraded my service to a tier that is 200Mbits on the downstream and discovered that I cannot get any more than 94Mbits down through the EA9200 with my direct wired computer. I am quite surprised as this was Linksys's top end home router until just a month ago.
I thought that the wired ports were Gig Ethernet. Am I missing something? Does anyone have a suggestion for a router that can handle the throughput?
After looking at the LAN/WAN throughput chart on this site, I'm going to guess maybe I have a flaky cable. I will swap it out this evening when I get home and see if that helps.
Check your modem as well - older ones might only be 100Base-T and that'll hold you back a bit ;)
Also, as you mentioned, the some modems were very sensitive to ethernet cable quality, and even if the modem and router both supported GiG, they would negotiate a 100Base-T connection..
Just to complete the story, the problem was finally solved by a hard reset of the router and re-configuring it. Shrug.
Linksys - meh, it happens...
Happens with most others as well - a reboot cleanses the soul sometimes...
Kinda weird the way it acted. Had to do a factory reset to get it to work correctly. I would assume that it was the ports only negotiating 100 vs gig but wireless to wireless was also slow as I started really digging into all that was being effected. In hind site, this may have been going on for a couple of weeks as file transfers have seemed a little slow.
May not have looked into it for a while longer if I hadn't upgraded my internet service.
