sm00thpapa
This is what the V1 and V1.1 should have been. Hopefully the BCM4366E really supports MU-MIMO.
https://wikidevi.com/wiki/Linksys_EA9500_v2
Can i buy the new router EA 9500 v2 ? in germany not available
Did you check your local stores or online like Amazon?Yes download software for the new router is in germany. but i can not buy it.
yes friend i have check the web and amazon uk. i can not see in the shopd the v2.
Thanks, also whilst you're there can you check if the power supply of the EA9500 (any version) is universal 100-240v or if its US 100-110v only?Not sure yet as they are still trying to get rid of old stock. I'm going to Best Buy now to see what they have on the shelves.
The External Photos document in the FCC listings shows three different external (brick) power supplies. All of them take in 100-240V.Thanks, also whilst you're there can you check if the power supply of the EA9500 (any version) is universal 100-240v or if its US 100-110v only?
cheers
sm00thpapa - Did they have any of the V2's on the shelf?Not sure yet as they are still trying to get rid of old stock. I'm going to Best Buy now to see what they have on the shelves.
Welcome To SNBForums
