Linksys wrt54g
crunchman
hello everyone
I am looking for a wrt54g Linksys wireless router, question is , witch one will not accept firmware upgrade.( ie 54gL v???
? is the wrt54g good or the wrt54gL the one to get
WRT54GL is specifically designed to accept alternate firmware.
hello everyone
Search e-Bay for a 54 already flashed with DD-WRT or Tomato.
Refurbished units are available for $25 - $40.
Look for Ver 1 - 4 as they have more memory and you can install higher gain antennas. Even then the memory is small compared to today's current routers.
The 54s are work horses and can be used for certain purposes, but they are twelve year old technology and don't have the processing power to handle today's higher speed connections. If you need WiFi greater than 25Mbps look elsewhere. the 54's radios are G only The Ethernet switching is fine for 100Mbps connections.
My WRT54G was retired many years ago because it constrained the net throughput of my modest cable modem service (20/1).
hey thank you all for the info and update, Iwant it just to play around with as I am now retired (satellite internet installer ) and back then I just did not have the time
I also want to ask what are the thoughts on the wrt 1900 ac ? other than price ?
Perfect application. I use the 54Gs I have to provide guest networks, bridges, repeaters and client adapters.
Enjoy!
hello everyone
WRT56G Version 4 or earlier if you want to go with OpenWRT or DDWRT...
Versions 5 and later are cost-reduced with the VXWorks OS - they can boot into a lite version of DDRWRT, but the reduced RAM and Flash footprints make them less desirable.
The WRT56GL's are, if I recall, respin's of the V3.1 version of the WRT54G, but that was a long time ago..
N Linksys Atlas Max 6E vs TP Link xe75 6E Mesh Wi-Fi Buying Advice 4
