Log filled with RTR-ADVERT
The_Bishop
Checked on my router this morning as web page loads seemed to be slow.
The system log is filled with these, seems to be every seven seconds or so:
Mar 2 07:28:17 dnsmasq-dhcp[10734]: RTR-ADVERT(br55) 2601:85:c702:fd0:400::
Mar 2 07:28:24 dnsmasq-dhcp[10734]: RTR-ADVERT(br55) 2601:85:c702:fd0:400::
Mar 2 07:28:32 dnsmasq-dhcp[10734]: RTR-ADVERT(br55) 2601:85:c702:fd0:400::
Mar 2 07:28:39 dnsmasq-dhcp[10734]: RTR-ADVERT(br55) 2601:85:c702:fd0:400::
Any ides on what's happening? I can tell it's related to IPV6 but I haven't had this pop up in the logs like this before.
Edit: It's persisting even after a router reboot.
Guest Network Pro doesn’t suppress this logging like the main network does when IPv6 is enabled. You can add quiet-ra to /jffs/configs/dnsmasq-1.conf.add but replace the 1 with whatever guest network instance you have. br55 suggests there might be a few.
