Logging question?
skeal
Part of the Furniture
Is this normal logging or do I have an issue here?
Jul 16 04:03:09 RT-AX88U-9D28 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) (phyId: 8) Link DOWN.
Jul 16 04:03:09 RT-AX88U-9D28 kernel: br0: port 1(eth1) entered disabled state
Jul 16 04:03:12 RT-AX88U-9D28 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) (phyId: 8) Link UP at 1000 mbps full duplex
Jul 16 04:03:12 RT-AX88U-9D28 kernel: br0: port 1(eth1) entered listening state
Jul 16 04:03:14 RT-AX88U-9D28 kernel: br0: port 1(eth1) entered learning state
Jul 16 04:03:16 RT-AX88U-9D28 kernel: br0: topology change detected, propagating
Jul 16 04:03:16 RT-AX88U-9D28 kernel: br0: port 1(eth1) entered forwarding state
It happens sometimes twice a day.
Whatever is connected to that port is disconnecting/reconnecting. Could be a device going into sleep mode, could be a bad network cable, could be a device rebooting... You'll have to investigate what is connected into that port.
Thanks I figured it out.
Who knew the numbering was messed up? For instance, the port on the back of the router named port 1 is actually seen as eth4 on bro and port 4 is eth1 on the same bro. Was it meant to be that confusing or...?
