Logs dnsmasq-dhcp [1512]
Unetwork
On my AX88U (Firmware 386.5_2) I receive these few lines after connecting a Wifi device, is this normal ?
I think it's just an indication, not a problem ?
For information, my 2,4 Ghz and 5 Ghz network have the default chanel in Auto and the DHCP part is configured like this.
I would like to point out that I have no problems with the connection or stability in Wifi, everything is rock solid.
Thanks for your feedbacks.
Perfectly normal messages.
P.S. There's absolutely no point in hiding private IP addresses in your output, like 192.168.x.y.
Thanks for this feedback, it reassures me for the Logs.
You are absolutely right, everyone can have the same addresses on the local network, no need to hide them except for the WAN.
Thank you again for your valuable advice.
