looking for a router that supports, vpn, igmp, igmp fast leave
Jvivek
Hello,
here are the following things i am looking for
I want to setup a vpn connection on the router, but i want certain private ip on lan to connect through this vpn connection while other computers on lan side to connect through normally. is this possible
I also need the router to support igmp, igmp fast leave
thanks
Only way to do what you want is to create two VLANS on different networks. You will probably have to go up to a small cisco router with IOS to accomplish.
Hope that helps
