lost all upload
bigcid10
what settings would cause my upload rate to drop like a rock
w/o router-rt-n66u 25d-4u
with router 25d-.7u
only changes from stock settings are
ipv6 enabled and working
vpn setup and enabled in router but disconnected in windows
some ports are opened for ftp,ssl,etc
but if I turn off vpn,ipv6 it's still the same
I'm using 178rm15 firmware
thank you,bigcid10
also ,I forgot QOS is enabled but made no difference when disabled
with router 25d-.7u
thank you,bigcid10
The first suspect would be QOS, especially if the upload rate was entered with the wrong unit (i.e. 3 Kbits instead of 3 Mbits). If the issue persist with QoS disabled, it could be either something on your network uploading a lot of stuff (look at P2P software, torrents, etc...) or it could also be an ISP-related issue - try power cycling your modem.
I tried disabling QOS but I didn't powercycle the router
should I have?
also the modem too?
ok,I found what was causing to slowdown
that program cfos that I was running
when I turned off traffic shaping it all came back
so now I have to figure out why
thank you
