Low NVRAM warning - how to fix this?
Livin
AC68U
No 3rd part apps, no VPN, no scripts, no QOS.
How to fix?
thx!
NVRAM Usage
64876 / 65536 bytes
JFFS 1.67 / 62.75 MB
I do not have any 3rd part apps or scripts and didnt have any QOS on.
How to fix?
thx!
NVRAM Usage
64876 / 65536 bytes
What router?
If you ever used OpenVPN (server or clients), go to each instance you previous used, and click on "Default" to erase any stored key/cert from nvram.
S iOS privacy warning new router ASUS Wi-Fi 10
