media bridge routing
eak
Thank you for 67_0! The new http certificate feature is a real time saver.
While I was installing 67_0 on my media bridge, I noticed there is no route table in that mode. I have two subnets in my configuration, so it would help to be able to specify a static route, since one of my DNS servers is on a different subnet from the media bridge, and if it gets that DNS from the DHCP server, it stops working.
you understand what a media bridge is , its basically a replacement for a long ethernet run , once you set a router to media bridge mode its basically a wireless adapter that you can connect wired clients to and pretty much nothing else as the router function for the most part have been bypassed
