Merlin 386.1_2 on AC68U conntrack error
jonaso
I recently upgraded my AC68U (master node in mesh network) to merlin 386.1_2,
and after this conntrack has stopped working.
admin@RT-AC68U-22A0:/tmp/home/root# conntrack -L
conntrack v1.4.5 (conntrack-tools): Operation failed: invalid parameters
I don't find anything in dmesg or syslog.
Any suggestions welcome,
Thanks!
/Jonas
admin@RT-AC68U-22A0:/tmp/home/root# lsmod
Module Size Used by Tainted: P
ip6t_LOG 4494 0
tdts_udbfw 25852 1
tdts_udb 180812 1 tdts_udbfw
tdts 417034 2 tdts_udbfw,tdts_udb
usblp 10321 0
thfsplus 84702 0
tntfs 493645 0
tfat 186782 0
ext2 52776 0
ext4 221674 0
nf_nat_h323 4761 0
nf_conntrack_h323 33807 1 nf_nat_h323
nf_nat_rtsp 3202 0
nf_conntrack_rtsp 4067 1 nf_nat_rtsp
nf_nat_ftp 1144 0
nf_conntrack_ftp 4909 1 nf_nat_ftp
crc16 1007 1 ext4
jbd2 48993 1 ext4
ext3 106409 0
ip6table_mangle 934 0
jbd 42367 1 ext3
mbcache 4599 3 ext2,ext4,ext3
usb_storage 34290 0
sg 19855 0
sd_mod 21983 0
scsi_wait_scan 416 0
scsi_mod 108738 3 usb_storage,sg,sd_mod
ohci_hcd 17926 0
ehci_hcd 32382 0
cdc_mbim 3137 0
qmi_wwan 5792 0
cdc_wdm 7252 2 cdc_mbim,qmi_wwan
cdc_ncm 8762 1 cdc_mbim
rndis_host 5256 0
cdc_ether 4036 1 rndis_host
asix 10856 0
cdc_acm 12614 0
usbnet 11900 6 cdc_mbim,qmi_wwan,cdc_ncm,rndis_host,cdc_ether,asix
usbcore 102572 14 usblp,usb_storage,ohci_hcd,ehci_hcd,cdc_mbim,qmi_wwan,cdc_wdm,cdc_ncm,rndis_host,cdc_ether,asix,cdc_acm,usbnet
mii 3367 2 asix,usbnet
ip6table_filter 750 1
nf_nat_pptp 1602 0
nf_conntrack_pptp 3419 1 nf_nat_pptp
nf_nat_proto_gre 887 1 nf_nat_pptp
nf_conntrack_proto_gre 3296 1 nf_conntrack_pptp
wl 4206833 0
dpsta 12782 1 wl
et 65170 0
igs 11992 1 wl
emf 15449 2 wl,igs
ctf 21199 0
jffs2 91274 1
zlib_deflate 19489 1 jffs2
Asus has extensively modified the conntrack code for their own use, so it cannot be relied upon to work as expected for other needs.
thanks for reply!
ok,
1) should it then been removed (a broken binary is sort of pointless)
2) is there an alternative ?
do you mean simply copying the "old" binary ?
I'm all for testing! Can you add it here ?
admin@RT-AC68U-22A0:/tmp/home/root# which conntrack
/usr/sbin/conntrack
Asus uses this for the new Parental Control code.
Either
netstat-nat
or
cat /proc/net/nf_conntrack
Should give you a list of tracked connections.
Do you have the Entware version of conntrack installed? That will produce the error you're seeing.
opkg status conntrack
No, I don't have Entware
Can you (or anyone) upload that version so I can try it ?
That won't work. The conntrack package has other required packages and needs the Entware libraries. It's not a standalone binary.
Btw, you say that the Entware version of conntrack will produce those errors...but I have the "plain" merlin version. What does that mean ?
I looked at source code for conntrack, it looks quite small,
could it be that the problem is actually in e.g libnetfilter_conntrack.so ??
admin@RT-AC68U-22A0:/tmp/home/root# ldd /usr/sbin/conntrack
libnetfilter_conntrack.so.3 => /usr/lib/libnetfilter_conntrack.so.3 (0x401f5000)
libmnl.so.0 => /usr/lib/libmnl.so.0 (0x400b7000)
libnfnetlink.so.0 => /usr/lib/libnfnetlink.so.0 (0x4008a000)
libc.so.0 => /lib/libc.so.0 (0x400c2000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x40136000)
ld-uClibc.so.0 => /lib/ld-uClibc.so.0 (0x4009e000)
I'm running Firmware Version: 384.17 (18 and 19 are causing too much trouble) I'm guessing 384.* is the last branch this works.
