Migrate in a new main router into existing AiMesh
BL_BL
Currently I have a small AiMesh consisting of a RT-AC5300 as main router, a RT-AC88U and some RT-AC68U nodes.
I want to replace the RT-AC5300 with a GT-AX11000.
Can factory-reset the GT-AX11000 and add that as a node and migrate things like DHCP table (and other settings) to the GT-AX11000, disconnect the RT-AC5300 and enable the GT-AX11000 as the new main router of the AiMesh?
One other thing, as I understand it the GT-AX11000 has WPA3, what happens if that is enabled (or can it be enabled?) since the other nodes doesn't support WPA3?
TIA!
