Minecraft port forward RT-AX82U
Koishukaze
I am unable to port forward, i have also allowed the firewall so i would like some help, this is a new router and worked before
If it's a new router connected to a cable modem it's likely that your WAN IP address has changed. Maybe that's the problem. How are you testing this?
I am testing via a laptop on the same network, i have 3 instances, one with local ip, public ip, and a custom ddns (lower priority), both public ip and custom ddns do not work, so it seems to issue is with the port forwarding
